Hi folks
I have a 1943 WC-57 Command Car that I am restoring.
Can anyone help me to figure out the hood numbers?
The frame number is 81670629
Built Card
https://goo.gl/photos/sjddaMgsMARoFNB76
Thanks a lot!!!
Randal
WC57 HOOD NUMBERS
- Private 1st Class
- My garage: 1943 Dodge WC-57 Command Car
1943 GMC CCKW 352 Open Cab
1945 Ford GPW
1963 Willys M38A1C
Re: WC57 HOOD NUMBERS
Someone else correct me if I'm wrong but here is what I come up with.
4594 WC-57s were produced using hood numbers from 20291158 to 20295751 and they started with serial number 81601050. It looked the the last group to be built.
Since your serial number is 81670629, it falls in that group so it's safe to say you had one of those 2029 numbers. Total production (all CCs) was 21697 and your Budd body number is 20517. The subtraction of those two numbers is 1180. Take 4594-1180 = 3414.
Add 20291158 + 3414 = 20294572
This would be correct if they built them like they build them today. But, back then they didn't have body numbers exactly aligning up with contract numbers on the assembly line so if your anywhere in the 2029 series as listed above you should be good.
I have a list of the 2029 numbers I have seen being used now and they are:
20295743
20295561
20295359
20295358
20294867
20294705
20294641
20294536
20294476
20292211
20291374
20291319
20290868
2029516
One of Pattons CC was 20295359 which somebody is using today.....
http://www.pattonthirdarmy.com/pattoncommandcar.shtml
20295743
20295561
20295359
20295358
20294867
20294705
20294641
20294536
20294476
20292211
20291374
20291319
20290868
2029516
1943 WC57
1943 WC57
Hi Steve,
Can you guesstimate the hood number for my Febr 12th 1945 Dodge WC51?
Frame no: 8174144
From the photo shoot for an article about my Dodge:
Build card:
Someone even suggested that my WC51 might even share the same number as with this Dodge WC51 ambulance from a very well known photograph: 2 2 5 5 9 0 4
Thanks,
Goran N
Frame no: 8174144
Build card:
Thanks,
Goran N
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Marked as an ambulance of the
Willys MBT
ACM no 57482
Manufactured: July 1943
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Your serial number is 81741448
Starting with serial number 81601050 the last batch, which was a quantity of 15,114 of WC-51s, were built. The hood numbers of that batch ranged from 2110000 to 2125113. That's about all I can say for the weapons carriers because the WC-51 and WC-52s had shared frame numbers.
It lists a quantity of 38,154 WC-52s also starting from serial number 81601050.
So I would say that your hood number should be between 2110000 and 2125113.
If it's a KD, I don't have registration number ranges for those.
1943 WC57
1943 WC57
- My garage: WC52
WC57 - Location: Massachusetts
My WC57 has the following info:
Frame # 81674456
Engine# T214-118263
Budd Body Tag# 4219-18029
DOD 5-27-1943
Hood# 20292211 (original #'s and stars, found on the tailgate as well)
Frame # 81674456
Engine# T214-118263
DOD 5-27-1943
Hola TimS,
Your car is WC-56 and no WC-57.
B.R., Juan.
B.R., Juan.
- Private 1st Class
1945 Ford GPW
1963 Willys M38A1C
Dear friends
Accordingly to the build card (attatched to the first post above), my WC-57 was buil in OCT 29 1943.
Is it possible to discover the date of delivery (DOD) to the US Army?
And how to decifrate all the informations registered on this build card?
Some info is easy to understand, but many others not.
Thank you!
Thank you!
