Body Number Plates
Body Number Plates
Hi folks,
I have purchased a set of repro data plates for my WC 53 as all of the originals were missing. However I have not been able to locate a supplier for the body number tag (data plate). Does anyone out there know someone who makes these? Or the exact domensions so I can get one done here in New Zealand?
1942 WC57 Command Car
1942 WC-53 Carry-All
Re: Body Number Plates
If your referring to the zinc Budd body tag, I don't think anybody reproduces those. You may want to list your request in the "market" section of this forum. Also keep an eye on Ebay. I have seen a couple of them come up. One was for an WC-54 and the other was for a command car WC-56/57.
1943 WC57
1943 WC57
- My garage: Dodge WC-57
I could probably get you one for a WC62 if that is better than nothing.. Not 100% sure but I can give it a shot.
Hi All,
thanks for your responses, I will probably sacrifice a spare repro data plate to make one, as I want to stamp the correct body number onto the plate. (I have the build card). I had hoped someone made repro's.
- Richard
- Private 1st Class
Hi Ian
the original body tag dimension (zinc)
and a repro (alu)
Regards
and a repro (alu)
Regards
Richard
1942 WC53
1942 WC53
What about the guy in Poland- "Lt. Horne" was the name he used to trade under on e-bay- I believe he made the data plates in zinc, perhaps he could knock one of the body tags out in zinc, too?
- My garage: 1944 WC63 Dodge
1957 M201 Hotchkiss
1950's Pollynorm Jeep Trailer
Ian, thanks for asking this question, it's one I've been pondering over for a while myself. Now another job to add to the list.
Richard, could you tell me what size and thread are the screws that fix the plates to the cowl please?
Cheers,
Chris.
Cheers,
Chris.
- Richard
- Private 1st Class
Cheers,
Chris.
On 53 the body tag is on the right pillar and I had installed 2 sheet metal screw N°6 -3/8"
Regards
Richard
1942 WC53
1942 WC53
1957 M201 Hotchkiss
Hi Richard,
Thank you for that.
Does anyone know if it's the same fixings for the cowl mounted plate or if they are a UNF/UNC thread?
Regards,
Chris.
Thank you for that.
Regards,
Chris.
Hi Richard, thanks for the drawing, that very helpful.
Chris, I understand that data plates that are specific to a vehicle (eg chassis number or body number) are riveted in place, the plates that are non-specific (radiator drain etc) were screwed in place with self taping screws.
1957 M201 Hotchkiss
Okay, thanks Ian.
Chris.
Chris.
1957 M201 Hotchkiss
Sorry to revive this old thread, but could anyone tell me the size of the rivets that fix the Serial Number Plate to the glove box door please?
Regards,
Chris.
Regards,
Chris.
