WC-26 Carryall Restoration
wareagle4590
Re: WC-26 Carryall Restoration
Post by wareagle4590 »
Thanks, will get with photobucket.
Wareagle
wareagle4590
For your 100% accurate WC-26 restoration you will need the square brass washers for the seat mounting. Check out ebay #111757668764
Wareagle
Phil H
My garage: VC-1 Command Car, WC-6 Command Car
GP Ford, , 1-Ton Nash Trailer, WC-22, WC-26, WC-11
Post by Phil H »
Long weekend, got several things done:
Replaced broken springs in driver and jump seat, took them to have covered.
Installed headliner.
Installed all the glass.
Also installed all the rear trim.
WC-6 Dodge #8666165 ?? 1941
WC-26 Dodge #81512402 ?? 1941
Phil H
Post by Phil H »
Also started on the top:
As Gordon outlined on his web site, made wood inserts to make up for the difference in height. Used 5/4 pressure treated deck lumber, fills the channel completly.
Stapled felt to wood insert.
Cut, test fit, remove and painted underside.
Installed roof panel, bent over tabs. Had to use three rivits as the tabs would not hold.
Phil H
Post by Phil H »
picked up fenders and hood from sandblaster, the fenders need a lot of work.
cut out rusted metal and welded in new metal. No body filler yet, just primer.
Front fenders in better shape. Put them on my test stand, will make it easer to dolly, fill and reprime.
Phil H
Post by Phil H »
Hood done, still have to make adjustments.
Phil H
Post by Phil H »
Both rear fenders are now dollied out, I find bolting them to the body helps hold them while you work the metal.
12th Air Force
My garage: Dodge WC51 built 1942. Former 4x4 MV: Dodge WC52, LR 109 ex MOD FFR (fitted for radio) Series IIA and Series III, Series III Stage1 V8 with Ambulance Body (ex. MOD), Series II 88 ex. BGS (German Border Patrol).
Post by 12th Air Force »
Hi Phil,
very impressive to see this result - compared with the first photo's and the original condition. :thumbup:
Having a look at your nicely repaired fenders I think I should replace my one's in the future too. :lol:
Great job, hopefully this beauty will be soon back on the road. :D
Keep 'em Rolling,
Joakim
daveyboy
Post by daveyboy »
May I ask. Who cut your glass? I know VPW carries the windshield glass as well as the side window glass, but the side window glass they carry is only for the trucks without metal surrounds like our 1/2 ton military uses. It's a different size. Did you find a vendor who carries it or had it cut custom?
aka “THE COUNT”
Phil H
Post by Phil H »
Joakim, Thank you very much
Phil H
Post by Phil H »
I used a local glass guy that services body shops in the area. I gave him the frames and the old glass for a pattern. All the glass for the carryall was $595. I don't know if he would ship or not, small opperation. If you can't find anyone local let me know and I will provide contact info.
Phil H
wareagle4590
Phil
The fender looks great and I did the same holding them in place while working on them. Did you or is there fender welt on the rear fenders?
Wareagle
Phil H
Post by Phil H »
Found the last hard to find items for the carryall. Came from a member of this board, thank you very much.
Started the repair process. I have already rebuilt and painted the springs, they are being covered next week.
Phil H
Post by Phil H »
The two front seats are done and installed.
Floor mat installed.
Front fenders are done.
Phil, where do you get the floor mat material? is it US made? I know where to get US made rubber matting but not sure if they have that pattern
