WC-26 Carryall Restoration
Phil H
My garage: VC-1 Command Car, WC-6 Command Car
GP Ford, , 1-Ton Nash Trailer, WC-22, WC-26, WC-11
Re: WC-26 Carryall Restoration
Post by Phil H »
I got the mat from Midwest Military, they are the only place I found that has the mat 46 inches wide. You need that for the carryall and the panel. Phil
WC-6 Dodge #8666165 ?? 1941
WC-26 Dodge #81512402 ?? 1941
is it precut or raw?
Phil H
Post by Phil H »
You can get eather way, this was pre cut.
Phil H
Post by Phil H »
Repairs made to seat frames, test fit in truck. Now off to the sandblaster!
I converted this extra drivers seat to a middle seat, the frame and sheet metal are the same.
Loffy770
My garage: Dodge WC-57
Post by Loffy770 »
Very nice, keep up the good work :thumbup:
Phil H
Post by Phil H »
Thank You.
Phil H
Post by Phil H »
Something I have done on my last three restorations is replace the steel hood pin with a solid brass brazing rod. No rust creeping out of the hinge, don't have to oil, and will not rust.
Loffy770
Post by Loffy770 »
Thanks for a great tip, will do the same on my hood :D
great idea thanks for the tip
Phil H
Post by Phil H »
I put the top on today, I have been dreading this. It was not bad, took about three hours.
Covered any sharp edges with seam sealer. I used a little contact glue on this edge to get the canvas to lay flat, but it was not realy needed.
Used wood pegs to hold the other side as I streached the canvas as I hammered in the rubber seal. Used a dul screw driver to push in the seal lip as I went along. Used water to make the seal go in a little easer.
Half way there.
Used a razor knife to cut the canvas under the seal.
Done.
superdave
My garage: M135, M37, M43, M151, M152, M275A2, M35A2, Gamma Goat, 1942 MK1 Bren gun Carrier, Laylend Daf. Iltis WC54 WC52
Post by superdave »
WOW I am in aw of your skills during this and the start of you other panel restoration. Keep up the great work as I love reading the updates on the restorations and keep the pictures coming as well :thumbup:
Andersun
Post by Andersun »
superdave wrote:WOW I am in aw of your skills during this and the start of you other panel restoration. Keep up the great work as I love reading the updates on the restorations and keep the pictures coming as well :thumbup:
Same here Phil, it's really a form of art. Keep the updates and pictures rolling!
1943 WC57
wareagle4590
Post by wareagle4590 »
Same here Phil. Wow!!!! I've made a file of your pictures for when I do the roof on my 41 Carryall. Thanks again for the roof.
Wareagle
looks great as all your work does. what kind of canvas do you use? more waterproof modern type or stock type?
Phil H
Post by Phil H »
Thank you, I do appreciate the feedback.
I used stock canvas from Beachwood. I have not decided to "coat" it with anything yet, but don't think I will.
