WC engine color scheme
KAE
Post by KAE »
Guys please,
do you have any link, photo, info or correct color code regarding colors of WC engineblock, bellhouse, gearbox, aircleaner, pipe for crankcase vent, waterpump....
thank you in advance!
Bud Wheel
Re: WC engine color scheme
Post by Bud Wheel »
air cleaner is black ...all the other items you listed are painted the same as the engine block...light gray
A search of this forum should turn up several posts with more detailed info including photos.
Hope this helps
John
A small collection of period correct HMVs
rgus
My garage: 1942 CCKW 129,XXX
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
1944 CHECKER 1 TON TRAILER
Post by rgus »
The origional Dodge color was "smoke grey". Here is an image of an origional part I saved off of my WC-52 restoration. It is the horn bracket and the side was aginst the engine away from a lot of dirt and the sun. It is probobly as close as you are gonna get without origional paint chips .
Phil P
My garage: 1944 Leyland Hippo MKII 6x4 GS 10 tonner
1944 Willys MB
1937 Sunbeam bicycle
1942 Ford GPW
Post by Phil P »
Dynamo, starter, horn, fan are satin black. The regulator cover is wrinkle finish black. The engine block, gearbox, bell housing, water pump, engine front cradle, thermostat elbow are smoke grey. The oil filler pipe/breather are gloss black though many are painted smoke grey. The gearbox tower is OD where it sticks through the floor. The radiator is gloss black. I painted the fan blade tips white so I could see them. The aircleaner is gloss black as is the aircleaner elbow. I painted the manifolds in woodstove black from Hy-Cote paints. It stands the heat from a woodstove and is half the price of Sperex. Sperex paint is very good but expensive. Two good coats of woodstove paint lasts and lasts. I also left the fuel pump 'natural, finish.
Phil
'Spirit of USS Arizona'
Feb '42 Ford GPW 'Yella Boyd'
KAE
Post by KAE »
Guys,
please, do you have correct code, number of engine gray color?
Archie
My garage: WC-48 Carryall
WC 12
Post by Archie »
I believe any Argent silver will do.
Archie
I like em old
wc 48
wc 12
KAE
Post by KAE »
Thank you Archie!
JohnnyTH
Post by JohnnyTH »
I found no traces of black on my 1942 wc-52 (former wc-55). Only OD.
My engine was painted green but that came of after using a presurewasher to clean it. I matched the grey as close as i could to the original. but sadly no colorcode as i mixed it myself.
Johnny
KAE
Post by KAE »
Johnny, thanks a lot!
Phil P
1944 Willys MB
1942 Ford GPW
Post by Phil P »
That looks about the right colour. Don't worry after it's been hot a few times and oil mist has been on it it will have changed colour. The horn should be satin black.
Phil
ng19delta
Post by ng19delta »
Now here's the REAL question: What color should the master cylinder for the brakes be? Is it O.D>, with the frame, or natural metal, or another color? (Same question goes for the wheel cylinders...)
brian
Post by brian »
wc-4
Phil P
1944 Willys MB
1942 Ford GPW
Post by Phil P »
Hi Scott.
Master cylinder OD. Paint over it with polyurethane clear varnish. Brake fluid doesn't attack it then. You always miss when your topping up. I don't think it matters about the wheel cylinders unless you're fitting glass brake drums! I gave mine a couple of coats of 'rattle can' black along with the inner faces of the back plates. I know the idea is to restore a vehicle exactley as the split second it rolled off the line but if you restore it as it was in service then colours tend to vairy depending on what was handy or in the stores.
Phil
Goose
Private
Post by Goose »
Found this old thread in a search for engine color. I see the transmission is also smoke grey. What color should the PTO box be?
Goose
ng19delta
Post by ng19delta »
PTO should match the transmission color, I believe- grey early, OD later... TC is OD in either case.
