K-38 Tool List
Posted: Thu Nov 04, 2010 6:23 am
There are 2 lists that contain different items. Here is list 1 of the 2 I hope to have the second some time next week.
TOOL VERSION 1 K-38 Trailer
Net wt. 98 pounds each, packed 123 pounds; cu ft., 5;spec. 318.
DL SET TE-56 (6R38056.1): Cable Splicers'; for cable construction and maintenance. Used with but does not include Trailer K-38.
Comprises:
1 AMPLIFIER (2C398), consists of 1 Amplifier, WE Co. #107A, 1 Cord, WE Co. W2BJ, equipped with Tool, WE Co. #513A, and Plug, WE Co. #47 and 1 Cord, WE Co. R2CF, equipped with 1 Receiver, WE Co. #108A, complete with 3 Vacuum Tubes, WE Co. type 32, or equal.
1 BAG (BQ2103), tool, Salisbury, nonmetallic, #30, Graybar, or equal.
6 BANDAGE TL-97 (6N9597).
3 BANDAGE (6N634-149), rubber, 4 inches by 14 feet, 33040, Amer E Co., or equal.
4 BATTERY BA-27 (3A27).
8 BEESWAX COMPOUND IC-2 (6N702).
12 BLADE (6Q8010-32), hacksaw, flexible, 32 teeth per inch, 10 inch, for hand frame.
12 BLADE (6Q8110-24), hacksaw, flexible, 24 teeth per inch, 10 inch, for hand frame.
50 BOARD (6Q10051) test, linen, splicers',numbered 51 to 99 and 1 to 51 (AT&T Co. spec. 6623).
50 BOARD (6Q10068) test, linen, splicers',numbered 1 to 68 (AT&T Co. spec. 6255).
1 BOOK (6D7100), specification, cable splicing, #4860 with supplements A,B, and C, ATT&T Co., or equal, with Binder #106, or equal.
1 CABLE DRESSER TL-90 (6Q15290).
1 CAN (6Z1716), safety, red, 3-gallon, 3/8-inch flexible spout #252, Protectoseal #247, or equal.
1 CAN ( ) , safety, green, 5-gallon #2067, Amer. E Co., or equal.
1 CLEANER (6Q27052), file, #2.
6 CLOTH (6N1620), cable wrapping, cotton, waterproof, approximately 24 by 18 inches.
6 CLOTH MC-74 (6N1574).
6 CLOTH MC-76 (6N1576).
2 CLOTH (6N1637), wiping, for upright joint, 1 3/4-inch center opening by 11-inch O.D., Williams, or equal.
2 CLOTH (6N1638), wiping, for upright joint, 3 3/4-inch center opening by 14-inch O.D., Williams, or equal.
10 DESICCANT (6G250), 1/2-pint, W. A. Hammond, or equal, AT&T Co. spec. AT-6882.
1 DIE (6Q31004), marking. steel figures, 1/4-inch set.
1 DIPPER ( ), paraffin, black pressed steel, 4 13/16-inch diameter at top, 3 1/4 inches deep, 1 3/4-pint capacity, mild steel hooked handle riveted on, AT&T Co. spec. 6679.
1 DRIFT PIN TL-81 (6Q31981).
1 DRIFT PIN TL-99 (6Q31999).
1 DRILL SET( ), Di-Forge, "Diamond," with type C holder Graybar, or equal.
1 FILE (6Q38030-8), flat 8-inch, bastard, Nicholson, or equal.
1 FILE (6Q38120-6), half-round, 6-inch, bastard, Nicholson, or equal.
10 FORM (6Q40004), soldering, for bonding ribbon, 7/8-inch, WE Co. or equal, AT&T Co. spec. 6531.
1 FRAME (6Q41000), hacksaw, adjustable, 8- to 12-inch
2 FUNNEL (6Z4027-8), metal, small, 1/2-pint
1 FURNACE ( ), plumbers', equipped with two 9 1/4-inch plumbers shield #3277, Clayton & Lambert #24A, or equal, 1 in use, 1 in spare.
1 HAMMER TL-39 (6Q49139).
1 HAMMER (6Q49600), double-faced, short neck, 2 1/4-pound, 15-inch over-all length, Vaughn & Bushnell, Graybar #13, or equal.
1 HAMMER ( ), riveting, cast steel, 18-ounce, Stanley-Atha #235, or equal, spec. 17-37.
3 HANDLE ( ), file, Millers Falls #448, or equal.
1 HANDLINE (6Z5045), aerial, 60 feet of 1/2-inch rope with ring spliced in one end, ring and open hook in other end, sheave block having shell integral with a hook, AT&T Co.spec 6859.
1 HANDSET ( ), telephone, lineman's, C.B. #1025, with cord and test clips, Kellogg, or equal.
1 HANDSET (4B1158), lineman's, with #4 dial and switch and equipped with W2BT cords and JP clips, WE Co. #1011BW. or equal.
2 HOOK (6Q52961), pot, 5/16-inch steel, 10 3/8-inch over-all, WE Co., or equal, AT&T Co. spec 6689.
2 HOOK ( ), shave, oval, 5-inch over-all, Wilcox & Crittenden #519 with sheath, or equal.
1 INSULATING COMPOUND IC-1 (6N3001).
1 KETTLE (6Q58013), compound, double-jacketed, 5-quart, Wall Mfg. Supply Co., or equal.
2 KNIFE TL-29 (6Q60229).
2 KNIFE 96Q600003), chipping, 3-inch blade with sheath, WE Co. #531388, or equal.
1 LADLE (6Q62531), pouring, 3 1/2-inch, 3/8-pint, Automatic Elec. "Unique" S-5712.
1 LADLE (6Q62530), melting, wrought-iron handle, double-lip, 3-inch.
10 MARLINE RP-2 (6Z6981).
1 MEGGER (3F3230), O-100-megohm, 500-volt, "Supper-Meg," James G. Biddle Co. #679, or equal.
1 MIRROR ( ), cable splicers', steel, chromium-plated case, WE Co., or equal.
1 pint OIL (6G1389), splicing, cold stripping, WE Co., or equal.
1 PAN (6R2321), drip, approximately 21 by 18 by 4 inches, smooth, polished, blued steel.
8 pounds PARAFIN WAX IC-4 (6N4004).
1 can PASTE (6N4102), soldering, 2-ounce.
3 rolls PASTER MC-73-A (6N4273A).
2 PICK (6R3002), test, complete with cord and test clip, AT&T Co. spec 6491.
1 PLIERS TL-103 (6R4603)
1 PLIERS TL-126 (6R4626)
2 POINT (6N4600), test, cable splicers', with cord and test clip, AT&T Co. spec. 6191
1 POT (6R6360), paint, nonspillable, Salisburry, or equal.
1 POT (6R6300), paraffin melting, 10-inch I.D. by 7 1/2 inches deep, capacity 9 quarts, with clamp-on lid, AT&T Co. spec. 6627.
1 POT (6R6304), paraffin melting, 12-inch I.D. by 9 inches deep, capacity 18 quarts, with clamp-on lid, AT&T Co. spec. 6627.
1 POT (6R6350C), plumbers' melting, 6 3/4 inch diameter.
1 PUNCH (6R7508), center, 1/2-inch.
1 PUNCH (6N4402), sleeve, 5/32-inch, Bell System standard, WE Co.,or equal.
1 PUNCH (6N4403), sleeve, 1/4-inch, Bell System standard, WE Co., or equal.
1 RASP(6R8210-12), half0round, 12-inch, bastard, less handle, Nicholson, or equal.
50 feet RIBBON (6N4903), bonding, copper, 3/8 inch wide, #16 B&S. Auto E Co., or equal.
2 RULE (6R9606), 6-foot, boxwood, "Zig-Zag," rivet-joint, Stanley #806, or equal.
1 SAW (6R11214), plumbers', similar to Disston #6, excep; 14-inch.
1 SCISSORS (6R13514), 6-inch.
1 SCREWDRIVER (6R15420), 3-inch, 1/4-inch tip, wood handle, 7 3/4-inch over-all.
1 SCREWDRIVER TL-21 (6R15310).
1 SCREWDRIVER TL-44 (6R16510).
1 SCREWDRIVER TL-106 (6R16810).
1 SCREWDRIVER SET TL-128 (6R19100).
6 boxes SLEEVE FT-97 (6N6010), 400 per box.
3 boxes SLEEVE FT-98 (6N6016), 300 per box.
1 SNIP (6R24011), tinners',Compton #10, or equal.
5 pounds SOLDER M-30 (6N7530),
1 spool SOLDER M-31 (6N7531).
5 pounds SOLDER M-33 (6N7533).
1 pound SOLDER (6N7600), wire, half and half, #10.
1 SOLDERING IRON TL-117 (6R24617).
1 SOLDERING IRON (6R24524H), size 3, 1 1/2-pound, with handle.
1 SOLDERING IRON (6R24540H), size 5, 2 1/2-pound, with handle.
1 SOLDERING IRON (6R24564H), size 8, 4-pound, with handle.
3 sticks STEARINE COMPOUND IC-3 (6N8003).
5 STRIP ( ), leather, 1/8 by 2 by 24 inches; for insulated joints.
1 TAPE (6R36025), 100-foot, measuring, steel, Lufkin Rival #246, or equal.
3 TAPE (6N8595), rubber, 2-inches wide, 30-foot roll.
2 TAPE TL-83 (6N8583).
2 TAPE TL-94 (6N8594).
1 TAPE TL-109 (6N8609).
2 rolls TAPE (6N8832-36), friction 2 inches wide, 1 1/2-pound roll.
1 TARPAULIN (6Z7510-3), 10-ounce, canvas, olive-drab duck, 12 by 16 feet.
6 TEST SET (3F4025), with cord and test clips, Kellogg Switchboard and Supply Co. #1025, or equal.
1 TEST SET (3F4004-1), splicers', portable, WE Co. #43A, or equal.
1 TEST SET (3F4004), splicers', portable, WE Co. #62A, or equal.
1 TEST SET (3F4004-3), splicers', portable, WE Co. #20C, or equal.
1 THERMOMETER (6Z8642), solder and paraffin, W.C. Dillion & Co. "Temperometer."
1 TOOL (6R41016B), screw driver and socket wrench, WE Co. #216-B, or equal.
1 TOOL (6R41701), wire braid stripper, Diamond, or equal.
1 TORCH (6R42100-32A), blow, gasoline, 1-quart, Clayton & Lambert Co. #32A, or equal.
1 WEDGE (6Z9430), lead cable, for Y joints, WE Co. #1, or equal.
1 WINDSHIELD (6Q43167/1), for #50 Dreadnaught Big Brute Splicers, formerly 6Q43617/1
200 feet WIRE W-72 (1A72).
200 feet WIRE W-101 (1B101).
1 WRENCH TL-111 (6R 55006)
Comprises:
