K-38 Tool List
wc 9 and 12 owner
K-38 Tool List
Post by wc 9 and 12 owner »
There are 2 lists that contain different items. Here is list 1 of the 2 I hope to have the second some time next week.
TOOL VERSION 1 K-38 Trailer
Net wt. 98 pounds each, packed 123 pounds; cu ft., 5;spec. 318.
DL SET TE-56 (6R38056.1): Cable Splicers'; for cable construction and maintenance. Used with but does not include Trailer K-38.
Comprises:
1 AMPLIFIER (2C398), consists of 1 Amplifier, WE Co. #107A, 1 Cord, WE Co. W2BJ, equipped with Tool, WE Co. #513A, and Plug, WE Co. #47 and 1 Cord, WE Co. R2CF, equipped with 1 Receiver, WE Co. #108A, complete with 3 Vacuum Tubes, WE Co. type 32, or equal.
1 BAG (BQ2103), tool, Salisbury, nonmetallic, #30, Graybar, or equal.
6 BANDAGE TL-97 (6N9597).
3 BANDAGE (6N634-149), rubber, 4 inches by 14 feet, 33040, Amer E Co., or equal.
4 BATTERY BA-27 (3A27).
8 BEESWAX COMPOUND IC-2 (6N702).
12 BLADE (6Q8010-32), hacksaw, flexible, 32 teeth per inch, 10 inch, for hand frame.
12 BLADE (6Q8110-24), hacksaw, flexible, 24 teeth per inch, 10 inch, for hand frame.
50 BOARD (6Q10051) test, linen, splicers',numbered 51 to 99 and 1 to 51 (AT&T Co. spec. 6623).
50 BOARD (6Q10068) test, linen, splicers',numbered 1 to 68 (AT&T Co. spec. 6255).
1 BOOK (6D7100), specification, cable splicing, #4860 with supplements A,B, and C, ATT&T Co., or equal, with Binder #106, or equal.
1 CABLE DRESSER TL-90 (6Q15290).
1 CAN (6Z1716), safety, red, 3-gallon, 3/8-inch flexible spout #252, Protectoseal #247, or equal.
1 CAN ( ) , safety, green, 5-gallon #2067, Amer. E Co., or equal.
1 CLEANER (6Q27052), file, #2.
6 CLOTH (6N1620), cable wrapping, cotton, waterproof, approximately 24 by 18 inches.
6 CLOTH MC-74 (6N1574).
6 CLOTH MC-76 (6N1576).
2 CLOTH (6N1637), wiping, for upright joint, 1 3/4-inch center opening by 11-inch O.D., Williams, or equal.
2 CLOTH (6N1638), wiping, for upright joint, 3 3/4-inch center opening by 14-inch O.D., Williams, or equal.
10 DESICCANT (6G250), 1/2-pint, W. A. Hammond, or equal, AT&T Co. spec. AT-6882.
1 DIE (6Q31004), marking. steel figures, 1/4-inch set.
1 DIPPER ( ), paraffin, black pressed steel, 4 13/16-inch diameter at top, 3 1/4 inches deep, 1 3/4-pint capacity, mild steel hooked handle riveted on, AT&T Co. spec. 6679.
1 DRIFT PIN TL-81 (6Q31981).
1 DRIFT PIN TL-99 (6Q31999).
1 DRILL SET( ), Di-Forge, "Diamond," with type C holder Graybar, or equal.
1 FILE (6Q38030-8), flat 8-inch, bastard, Nicholson, or equal.
1 FILE (6Q38120-6), half-round, 6-inch, bastard, Nicholson, or equal.
10 FORM (6Q40004), soldering, for bonding ribbon, 7/8-inch, WE Co. or equal, AT&T Co. spec. 6531.
1 FRAME (6Q41000), hacksaw, adjustable, 8- to 12-inch
2 FUNNEL (6Z4027-8), metal, small, 1/2-pint
1 FURNACE ( ), plumbers', equipped with two 9 1/4-inch plumbers shield #3277, Clayton & Lambert #24A, or equal, 1 in use, 1 in spare.
1 HAMMER TL-39 (6Q49139).
1 HAMMER (6Q49600), double-faced, short neck, 2 1/4-pound, 15-inch over-all length, Vaughn & Bushnell, Graybar #13, or equal.
1 HAMMER ( ), riveting, cast steel, 18-ounce, Stanley-Atha #235, or equal, spec. 17-37.
3 HANDLE ( ), file, Millers Falls #448, or equal.
1 HANDLINE (6Z5045), aerial, 60 feet of 1/2-inch rope with ring spliced in one end, ring and open hook in other end, sheave block having shell integral with a hook, AT&T Co.spec 6859.
1 HANDSET ( ), telephone, lineman's, C.B. #1025, with cord and test clips, Kellogg, or equal.
1 HANDSET (4B1158), lineman's, with #4 dial and switch and equipped with W2BT cords and JP clips, WE Co. #1011BW. or equal.
2 HOOK (6Q52961), pot, 5/16-inch steel, 10 3/8-inch over-all, WE Co., or equal, AT&T Co. spec 6689.
2 HOOK ( ), shave, oval, 5-inch over-all, Wilcox & Crittenden #519 with sheath, or equal.
1 INSULATING COMPOUND IC-1 (6N3001).
1 KETTLE (6Q58013), compound, double-jacketed, 5-quart, Wall Mfg. Supply Co., or equal.
2 KNIFE TL-29 (6Q60229).
2 KNIFE 96Q600003), chipping, 3-inch blade with sheath, WE Co. #531388, or equal.
1 LADLE (6Q62531), pouring, 3 1/2-inch, 3/8-pint, Automatic Elec. "Unique" S-5712.
1 LADLE (6Q62530), melting, wrought-iron handle, double-lip, 3-inch.
10 MARLINE RP-2 (6Z6981).
1 MEGGER (3F3230), O-100-megohm, 500-volt, "Supper-Meg," James G. Biddle Co. #679, or equal.
1 MIRROR ( ), cable splicers', steel, chromium-plated case, WE Co., or equal.
1 pint OIL (6G1389), splicing, cold stripping, WE Co., or equal.
1 PAN (6R2321), drip, approximately 21 by 18 by 4 inches, smooth, polished, blued steel.
8 pounds PARAFIN WAX IC-4 (6N4004).
1 can PASTE (6N4102), soldering, 2-ounce.
3 rolls PASTER MC-73-A (6N4273A).
2 PICK (6R3002), test, complete with cord and test clip, AT&T Co. spec 6491.
1 PLIERS TL-103 (6R4603)
1 PLIERS TL-126 (6R4626)
2 POINT (6N4600), test, cable splicers', with cord and test clip, AT&T Co. spec. 6191
1 POT (6R6360), paint, nonspillable, Salisburry, or equal.
1 POT (6R6300), paraffin melting, 10-inch I.D. by 7 1/2 inches deep, capacity 9 quarts, with clamp-on lid, AT&T Co. spec. 6627.
1 POT (6R6304), paraffin melting, 12-inch I.D. by 9 inches deep, capacity 18 quarts, with clamp-on lid, AT&T Co. spec. 6627.
1 POT (6R6350C), plumbers' melting, 6 3/4 inch diameter.
1 PUNCH (6R7508), center, 1/2-inch.
1 PUNCH (6N4402), sleeve, 5/32-inch, Bell System standard, WE Co.,or equal.
1 PUNCH (6N4403), sleeve, 1/4-inch, Bell System standard, WE Co., or equal.
1 RASP(6R8210-12), half0round, 12-inch, bastard, less handle, Nicholson, or equal.
50 feet RIBBON (6N4903), bonding, copper, 3/8 inch wide, #16 B&S. Auto E Co., or equal.
2 RULE (6R9606), 6-foot, boxwood, "Zig-Zag," rivet-joint, Stanley #806, or equal.
1 SAW (6R11214), plumbers', similar to Disston #6, excep; 14-inch.
1 SCISSORS (6R13514), 6-inch.
1 SCREWDRIVER (6R15420), 3-inch, 1/4-inch tip, wood handle, 7 3/4-inch over-all.
1 SCREWDRIVER TL-21 (6R15310).
1 SCREWDRIVER TL-44 (6R16510).
1 SCREWDRIVER TL-106 (6R16810).
1 SCREWDRIVER SET TL-128 (6R19100).
6 boxes SLEEVE FT-97 (6N6010), 400 per box.
3 boxes SLEEVE FT-98 (6N6016), 300 per box.
1 SNIP (6R24011), tinners',Compton #10, or equal.
5 pounds SOLDER M-30 (6N7530),
1 spool SOLDER M-31 (6N7531).
5 pounds SOLDER M-33 (6N7533).
1 pound SOLDER (6N7600), wire, half and half, #10.
1 SOLDERING IRON TL-117 (6R24617).
1 SOLDERING IRON (6R24524H), size 3, 1 1/2-pound, with handle.
1 SOLDERING IRON (6R24540H), size 5, 2 1/2-pound, with handle.
1 SOLDERING IRON (6R24564H), size 8, 4-pound, with handle.
3 sticks STEARINE COMPOUND IC-3 (6N8003).
5 STRIP ( ), leather, 1/8 by 2 by 24 inches; for insulated joints.
1 TAPE (6R36025), 100-foot, measuring, steel, Lufkin Rival #246, or equal.
3 TAPE (6N8595), rubber, 2-inches wide, 30-foot roll.
2 TAPE TL-83 (6N8583).
2 TAPE TL-94 (6N8594).
1 TAPE TL-109 (6N8609).
2 rolls TAPE (6N8832-36), friction 2 inches wide, 1 1/2-pound roll.
1 TARPAULIN (6Z7510-3), 10-ounce, canvas, olive-drab duck, 12 by 16 feet.
6 TEST SET (3F4025), with cord and test clips, Kellogg Switchboard and Supply Co. #1025, or equal.
1 TEST SET (3F4004-1), splicers', portable, WE Co. #43A, or equal.
1 TEST SET (3F4004), splicers', portable, WE Co. #62A, or equal.
1 TEST SET (3F4004-3), splicers', portable, WE Co. #20C, or equal.
1 THERMOMETER (6Z8642), solder and paraffin, W.C. Dillion & Co. "Temperometer."
1 TOOL (6R41016B), screw driver and socket wrench, WE Co. #216-B, or equal.
1 TOOL (6R41701), wire braid stripper, Diamond, or equal.
1 TORCH (6R42100-32A), blow, gasoline, 1-quart, Clayton & Lambert Co. #32A, or equal.
1 WEDGE (6Z9430), lead cable, for Y joints, WE Co. #1, or equal.
1 WINDSHIELD (6Q43167/1), for #50 Dreadnaught Big Brute Splicers, formerly 6Q43617/1
200 feet WIRE W-72 (1A72).
200 feet WIRE W-101 (1B101).
1 WRENCH TL-111 (6R 55006)
General Chesty Puller
Ken J
194? Ben Hur Trailer
Re: K-38 Tool List
Post by Ken J »
:thumbup: :thumbup: :thumbup:
wc 9 and 12 owner
Re: K-38 Tool List
TOOL VERSION 2 K-38 Trailer
DL SET TE-56-A (6R38056A): Cable Splicers'; for cable construction and maintenance. Used with but does not include Trailer K-38.
Comprises:
25 ANCHOR (6Z284-4), hammer, drive 1/4- by 1-inch, Diamond, or equal.
25 ANCHOR (6Z284-6), hammer, drive 1/4- by 1 1/2-inch, Diamond, or equal.
6 rolls BANDAGE TL-97 (6N9597).
3 rolls BANDAGE (6N634-14), rubber, 4 inches by 14 feet, #3040, Amer E Co., or equal.
6 BATTERY BA-2 (3A2); formerly 3A6571.
4 BATTERY BA-23 (3A23); 4 used in Test Set 1020-C.
6 BATTERY BA-27 (3A27); formerly 3A6570.
8 BATTERY BA-27 (3A27); 2 used in FLASHLIGHT TL-122-A, 6 spare.
1 BELT LC-23-B (6Q4523B-40) or LC-23-A (6Q4523A-40), 40 inch length, lineman's size 22.
4 BOARD (6Q10001-51), fiber test, 52-hole, 1-51, Auto E. Co. #210, Kellogg #810, or equal.
4 BOARD (6Q10002-101), fiber test, 52-hole, 52-101, Auto E. Co. #811, Kellogg #811, or equal.
2 BOARD (6Q10003-202), fiber test, 52-hole, 102-152, Auto E. Co. #812, Kellogg #812, or equal.
2 BOARD (6Q10003-253), fiber test, 52-hole, 152-202, Auto E. Co. #813, Kellogg #813, or equal.
2 BOARD (6Q10004-203), fiber test, 52-hole, 203-253, Auto E. Co. #814, Kellogg #814, or equal.
2 BOARD (6Q10051), fiber test, 52-hole, 253-303, Auto E. Co. #815, Kellogg #815, or equal.
6 BOOK (6D7101), specification, AT&T Co. with six Binder #106, or equal
12 CLAMP (5B3508), bonding ribbon, rolled zinc, 1/2-inch wide, 5/16-inch holes, WE Co. #510982, or equal.
1 CLEANER (6Q27052), file, Nicholson #2, or equal.
1 pair CLIMBERS LC-5 (6Q28205).
12 CLIP ( ), transfer, AT&T Co. spec. 6869, or equal.
6 CLOTH (6N1621), cable wrapping, cotton, waterproof, approximately 25 by 40 inches, Auto E Co. #546, or equal.
1 COIL (3C395), exploring, WE Co. #75-A or equal; for use with WE Co. #108 amplifier.
6 CORD (3EW2AK), test with clips, WE Co. #W2AK, or equal.
10 cans DESICCANT (6G250-1), 1/2-pint, W. A. Hammond Drierite Co., or equal.
1 set DIES (6Q31004), marking, steel figures, 1/4-inch set.
1 set DIES (6Q31104), marking, steel figures, 1/4-inch set
1 DIPPER ( 6Q31716), paraffin, black pressed steel, 4 13/16-inch diameter at top, 3 1/4 inches deep, 1 3/4-pint capacity, mild steel hooked handle riveted on.
1 DRESSER 96Q31966), cable-wood, WE Co. dwg. 466-13, or equal.
1 DRIFT PIN TL-98 (6Q31998).
1 DRILL (6Q35311), 4-point, 1/4 inch, 8 inches long, "Diamond N," or equal.
1 DRILL (6Q35310), 4-point, 3/8 inch, 8 inches long, "Diamond N," or equal.
1 DRILL (6Q35312), 4-point, 1/2 inch, 8 inches long, "Diamond N," or equal.
1 DRILL (6Q35313), 4-point, 3/4 inch, 8 inches long, "Diamond N," or equal.
1 DRILL SET( 6Q35309 ), Di-Forge, "Diamond," with type C holder, Graybar, or equal.
1 FILE (6Q38027), combination, splicers', WE Co. spec. type H, or equal.
1 FILE (6Q38030-8), flat, 8-inch, bastard.
1 FILE (6Q38120-6), half-round, 6-inch, bastard.
1 FLASHLIGHT TL-122-A (6Z4002A.1).
1 FORM (6Q40003), bonding tool, aluminum, aerial, Slindelar Bonding Tool Co., or equal.
1 FRAME (6Q41000), hacksaw, adjustable, 8- to 12-inch.
2 FUNNEL (6Z4021-8), seamless, small, 1/2-pint, Masback #1062N, or equal.
1 FURNACE (6Q43167 ), with both gasoline and kerosene orifices, wrench, cleaning needle, and 7 5/8-inch by 5 1/2-inch hood, Wall Mfg. Supply Co. #50 Dreadnaught big Brute Splicers', or equal.
1 HAMMER (6Q49600), lineman's, double-faced, 2 1/4-pound, Bell System Pattern, Vaughan & Bushnell, Graybar #13.
1 HAMMER ( 6Q50018 ), riveting, 18-ounce.
3 HANDLE ( 6Q51131-5), file, Millers Falls #448, or equal.
3 HANDLE ( 6Q51185-5.1), soldering iron, spec. NN-H-106.
1 HANDLINE (6Z5045), aerial, 60 feet of 1/2-inch rope with ring spliced in one end, ring and open hook in other end, sheave block having shell integral with a hook, AT&T Co. spec 6859.
1 HANDSET ( 4B1158), lineman's with #4 dial and switch; equipped with W2BT cords and JP clips, WE Co. #1011BW, or equal.
1 HOOK (6253100), manhole cover, Cope Inc. type "A," or equal.
2 HOOK (6Q52961), pot, 5/16-inch steel, 10 3/8-inch over-all, WE Co., or equal.
2 HOOK (6Q53519), shave, oval, 5 3/4 inches over-all, with sheath, Pexto, Bell Systems Pattern, or equal.
10 pounds INSULATING COMPOUND IC-5 (6N3005).
1 KIT (6Z6600), first-aid, 5 by 4 by 3 inches, Johnson & Johnson Co., or equal.
2 KNIFE ( ), chipping, 3-inch blade with sheath, WE Co. #531388, or equal.
1 LADLE (6Q62531), pouring, 3 1/2-inch, 3/8-pint, Auto E Co. #S-5712.
10 pounds MARLINE RP-2 (6Z6981).
1 MEGGER (3F3230), "Supper-Meg," O-100-megohm, 500-volt, James G. Biddle #619, or equal.
1 MIRROR (6N3100), cable splicers', steel, chromium-plated case, WE Co., or equal.
5 pounds OAKUM (6Z7250), plumbers', 7-strand, 1 3/4-inch diameter, untarred, Manning, Mazwell, & Moore, or equal.
1 can OIL (6G1385), neat's-foot, 1-pint.
1 can Oil (6G1389), splicing, cold stripping, in pint can, WE Co., or equal.
1 can PAINT (6G1409), asphalt, 1-pint.
1 PAN (6R2321), drip, approximately 21 by 18 by 4 inches, smooth, polished, blued steel, All-Steel Equip. Co., or equal.
2 PICK (6R3002), test, complete with cord and test clip.
1 PLIERS TL-107 (6R4607)
2 POINT (6N4600), test, cable splicers', with cord and test clips.
1 POT (6R6360), paint, P.B., nonspillable, Salisburry, or equal.
1 POT (6R6300.1), paraffin melting, 10-inch I.D. by 7 1/2 inches deep, with clamp-on lid, capacity 9 quarts.
1 POT (6R6350D), plumbers' melting, 6 inch.
1 SAW (6R10314), cable, 14-inch, E.C. Atkins324, or equal.
2 SCISSORS (6R38005/1), 5-inch, electricians', Wiss #175E, or equal.
24 SCREW (5B10004-2.5), lag, steel, galvanized, 1/4- by 2 1/2-inch.
48 SCREW (6L9110-8), wood, round head, steel, galvanized, 1-inch, #10.
48 SCREW (5B14010-20), wood, round head, steel, galvanized, 2 1/2-inch, #10.
1SCREWDRIVER TL-21 (6R15310).
1 SHOVEL (6R22010), manhole, Bell System Pattern #70, WE Co., or equal.
2 boxes SLEEVE FT-96 (6N6008), 700 per box.
2 boxes SLEEVE FT-98 (6N6016), 300 per box.
1 roll SLEEVING FT-90 (6N6890), Auto E Co. #2, or equal.
50 pounds SOLDER (6N7605), arsenic content, in pigs, Belmont S&R Works, Inc., or equal.
9 pounds SOLDER (6N7606), stearine core, Bell System, WE Co., or equal.
1 SOLDERING IRON (6R24524-1), size 3.
1 SOLDERING IRON (6R24540), size 5.
1 SOLDERING IRON (6R24564), size 8.
6 sticks STEARINE COMPOUND IC-3 (6N8003).
5 STRIP (6R32605), leather, 1/8- by 2- by 24 inch strap leather; for insulated joints.
10 SUPPORT (6R32800), aerial cable, 22-inch, #3, national %3, or equal.
10 SUPPORT (6R32801), aerial cable, 22-inch, #5, WE Co., or equal.
12 TAGS (4z7293), cable, round, Bell System, WE Co., or equal.
12 TAGS (4Z7294), cable, octagonal, Bell System, WE Co., or equal.
12 TAGS (4Z7295), terminal, Bell System, WE Co., or equal.
2 TAPE TL-192 (6N8592).
3 rolls TAPE (6N8835), lead serving, national Lead Co., or equal.
1 roll TAPE (6R36046), measuring, linen, 5/8 inch wide, 100 feet long, Lufkin Rival #406, K and E 7495T; formerly 8A3730-4.
3 rolls TAPE (6N8595), rubber, 2-inches wide, 30-foot roll.
6 rolls TAPE 96N8932), scotch, electrical, tan, 1/2 inch by 36 yards, Bell System, WE Co., or equal; formerly 8A3730-4.
1 TEST SET I-51 (3F4051), splicers', portable, WE Co. #1020-C, or equal.
1 TEST SET (3F4051C), splicers', portable, WE Co. model 76A.
2 TEST SET (3F4004), splicers', portable, WE Co. #62A, or equal.
1 THERMOMETER (6Z8642), solder and paraffin, W.C. Dillion & Co. "Temperometer," or equal.
1 TIP (6R24617/1); for SOLDERING IRON TL-117; spare.
1 TOOL (6R41016B), screwdriver and socket wrench, WE Co. #216-B, or equal.
1 TORCH (6R42100-79A), blow, gasoline, 1-quart capacity, Bernz #79A Dreadnaught Heavy Duty, or equal.
1 TROUGH (6Z8719), paraffin, 14- by 28-inch, brass grommet in each corner, AT&T Co. Standard spec. 6361, or equal.
6 TUBE VT-44 (2T44); for WE Co. amplifier #108A; 3 in use, 3 spare.
2 TUBE (2V1A7GT), RCA 31A7GT; for WE Co. 76-A test set; 1 in use, 1 spare.
2 TUBE (2V3Q5GT/G), RCA 3Q5GT/G; for WE Co. 76-A test set; 1 in use, 1 spare.
1 VISE (6R47016), 2 1/2-inch jaw, swivel base, stationary jaw, Stanley #710, or equal.
12 WEDGE (6Z9430), lead cable, for Y joints, WE Co. #1, or equal
1 WINDSHIELD (6Q43167/1), for #50 Dreadnaught Big Brute Splicer, or equal.
100 feet WIRE (1A890), lead lashing, tinned bronze case.
1 pound WIRE (1A812.6), tie, copper, 0.080, 17 inches long, Bell System, WE Co., or equal.
1 WRENCH (6R57415), socket, linemans', Chance #154, or equal.
