Blackout driving light wiring
I have a question on the wiring for the blackout driving light wiring. There is a grounding wire in the bucket and a live wire thu the back, where does the ground wire hook to? Thanks Andy
Re: Blackout driving light wiring
It should have a spot inside for the ground wire. inside the light housing. Good luck, Bill.
Thanks Bill, yes I see the ground wire mounted to the housing itself, but where do I screw it to? Thanks Andy
one end is riveted to the bucket, the other end is screwed to a tab on the light retaining ring. so it grounds the outside of the sockett.
BB
BB
wc-4
wc-4
Cool
, I just went and took a look in my light parts box and found the ring, Thanks Brain. Andy
![Cool 8)](./images/smilies/icon_cool.gif)
