OILS SEAL NUT
samason
OILS SEAL NUT
Post by samason »
Does anybody know who has the oil seal bearing lock nut for CCKW Banjo rear axle?
retro-roco
Re: OILS SEAL NUT
Post by retro-roco »
I think thay are listed on ebay right now, if they're the same as the Chevy G506 banjo axle lock nuts.
Kirk Gustafson
Item Coy, 23 Regt, 2 Inf Div
WWII HRS
motto
Re: OILS SEAL NUT
Post by motto »
An interesting point about these seals is that the 1 1/2 Ton 4x2 Chev model 4403 etc which has an identical axle tube/wheel bearing/ adjusting nut/lock washer setup doesn't have the seal only a second nut same as the first.
I would think that the difference is that the all wheel drive trucks were for possible off road use where side slopes could be encountered. I covered many thousands of miles over many years with one of these 4x2 Chevs and the lack of a seal in this area was not a problem and I wasn't frightened to take the truck wherever I thought it would go.
