thius is for the G506, plain jane cargo bed..Now that I am about to mount the new bed onto my chassis, And have the gas tank out currently for cleaning/refurb, I would like to address the proper mounting of the gas take filler tube.
When I got this truck, it had been converted to a dump body. As such, the PO supported the loose top end of the filler/cap with a peice of strap and two sheet metal screws into the cab. this does not look proper, but who knows.
Was it attached at some location to the front panel of the cargo bed or is the cab mounting proper.
Looking for a picture to see how its done. Looked thru every pic I have collected and in diagrams in the two TM's and the SNL book I have, and I cant see this feature.
Anyone have a good picture of the gas filler tube mounting?
aka “THE COUNT”
aka “THE COUNT”
Re: Anyone have a good picture of the gas filler tube mounti
Hey Daveyboy, if I make it by the house in the next couple of week, I will take a picture of it for You. Thank Andy, Yes I did get a new camera
Davey,
Please see the attached photos. On my truck the fuel tank filler bracket consists of a wood block, a bent piece of flat plate, and two bolts with nuts and lock washers to hold it to the front of the bed. You can see this picture the strap and bolts. Check the bed drawings I sent you previously for the hole dimensions.
This photo show the profile of the wood block, as the origianl dark paint in the middle of the yellow. You can see how the corners were notched. the fuel filler tube is simply "sandwiched" between the wood block and the steel strap.
Kirk Gustafson
Item Coy, 23 Regt, 2 Inf Div
WWII HRS
WWII HRS
thanks Kirk!
And Andy, by all means!
Dave
Dave
aka “THE COUNT”
aka “THE COUNT”
Hey Dave, I'll be home on Sunday. Thanks Andy
Hey Daveyboy, let me know if you get the pictures. sent them to your yahoo address, had to get help from my Daughter to do it, old Dad was lost
hope they help. Thanks Andy
got the pix, Andy.. I didnt realize you sent to my other account!
And it was from an email address I didnt recognize! I found them and thank you once again!
aka “THE COUNT”
aka “THE COUNT”
Hey Daveyboy, hows the bed doing? Did the pictures help any? Thanks Andy
