FOUND: cargo box mounting springs
Posted: Sat Jan 30, 2010 1:00 pm
by daveyboy
***found locally.. thanks all!
I need a set of springs, the heavy coil type as used for the flex corners on cabs. Need two. No matter what lenght. Probably for 3/8-1/2" diameter bolt? Not sure.
Anyone?
wc57doggieboy@yahoo.com
Re: NEED: cab spring mounts
Posted: Sat Jan 30, 2010 2:08 pm
by retro-roco
Dave,
I'm having trouble understanding what springs you're asking for... Are these for a Chevy closed cab??
Posted: Sat Jan 30, 2010 3:21 pm
by daveyboy
hey Kirk,
actually, I would LIKE to find the longer 4-5" springs used to mount the chevy cargo bed to the frame.. thee is a long bolt that goes thru the spring, thru the front bottom lip on the front panel of the bed, thru the bracket and wood block and into the frame mounted angle iron mount,.
Inside the inner bed panel is this spring. Like i said, I think its like 4-5 inches long. I have a picture, but cant [post due to size.
See my other request on this site with a picture:
http://www.g503.com/forums/viewtopic.ph ... 71#p907471
I was hoping to find these first. BUT if I cant, I remember seeing these same type of springs on cab mounting, on Old Dodges. Just shorter
I would settle for these if I cant find the cargo bed springs first.
Got any extra's of these springs by chance?
