My Beep
My Beep
Hi all, here it is my one. Have a look, comments wellcome.
Here there is the first question: I do not know whether of not this coul be original, I have only seen one old pic with similar bows.
this is the pic
The top bows corner are not oginal, and one piece of wood is broken. Where and how much would cost the six original corners? And what about the kind of wood for the top?
Here, a look of the full rear floor. Another problem, the fuel gauge does not work well, and i think that the problem is in the mechanism to measure the amout of fuel inside the tank. To ways: a hole on the wood jus in the exact place, or dissamble the tank from the rear. What do you recomend? It is extrange because when tunr the truck on, the needle moves a little but not enough, so electricity is arriving at the gauge.
This one just to show the rear seats. the rear seats are not confortable when the top bows are remove aren´t they ?
and what about this tag?
And what about the gauges? which ones are originals and which not? and about the handles?
and tha´s all. now getting documents to can drive street legally. I want to buy the full canvas with doors, but a lot of money...
Regards
this is the pic
Regards
1944 WC 51
couple willys couple land rover and an oldsmobile.
Re: My Beep
Bow corners are available probably about $20.00 each. The floor is not original and looks like a sheet of plywood so you will need new wood and a set of skid strips. The troop seats are not original so some works wil be needed there. When a vehicle gets to be 65+ years old many modifications have been made. In the original bed floor there woild have been a round steel inspection plate over the fuel tank sending unit which would have made it easy to check the grounds and replace the unit if necessary. If you restore the bed floor you can do the sending unit at the same time
Re: My Beep
I like your vehicle because it looks like a "driver" and not a "trailer queen". GIs have always made modifications at the motor pool level...and that won't change. Your vehicle shows the history of the guys who actually used it for its intended purpose. Make changes to suit your taste, and pocket book. Enjoy it, and drive on.
- My garage: 1942 WC51
Re: My Beep
I have to agree with Uglyranger, I like the look of a "driver". Your truck looks great....
Mike
Mike
Re: My Beep
Hi all,
thanks for your comments. Where to find the top bow corners?
Regards
Regards
1944 WC 51
Re: My Beep
One extra question: where can I buy the tool to up the truck for replace a wheel? and what about the tool to disscreew the wheel screews? Does any body has the original ones?
May thanks
Will
May thanks
Will
1944 WC 51
1943 WC-54 81635383
1943 GPW 146954
1945 WC52 818682 "MO"
1943 WC63 82009972 "BIG MO"
Re: My Beep
I would call John Bizel the owner of Midwest Military. I suspect he can hook you up with all you need. If not Vintage Power Wagons can but they are usually quite a bit more expensive. Both have very good websights.
Re: My Beep
Just click on the sites below, and it will take you there:
Midwest Military
http://www.midwestmil.com/
Vintage Power Wagon
http://www.vintagepowerwagons.com/
Adirondack Dodge Parts and Surplus
www.adirondackdodgeparts.com
Memphis Equipment
http://www.memphisequipment.com/
Midwest Military
Vintage Power Wagon
Memphis Equipment
194? Ben Hur Trailer
Re: My Beep
Beep:
REALLY NICE! Glad you drive it.
Where were the pictures taken? Looks like a church to the front right, but bunkers for explosives behind the truck to its right????
Re: My Beep
Rgus,
john seems to not have the corner bows, so I´ll try in power wagons. Thanks for your help.
Uglyranger, thanks for posting the addresses. Ken J, This is a coloured WWII picture, Isn´t it?
Nooooo this is the village where I have the truck. This village has more that 500 years old. You are right with the church, but wrong with the bunkers: they are "bodegas" the place where the wine is done.
Regards
Regards
1944 WC 51
- Florence
Re: My Beep
Great Truck in a beautifull landscape/village!
Like the top bows and the wood, together with that vintage photo it shows a useful GI modification - and a special Truck today next to some trailer queens which someimes all look the same.
Sylvia
Sylvia
http://www.command-car.com
Dodge Build Card collection:
Re: My Beep
So that is in Spain??
Re: My Beep
that´s it, castilla la vieja (the old castilla) it is like old castle......
1944 WC 51
1943 WC-54 81635383
1943 GPW 146954
Re: My Beep
Vintage Power Wagon had NOS BOW corners a year or so ago. They had surface rust but a trip through the blast cabinet and they look brand new. They were $20.00 each at that time.
Re: My Beep
Hola Beep, como estas?.
Yo gusto sus Beep, yo tengo una Command Car.
I believe you will find the problem with the fuel gauge will be in the sender unit inside the tank. It is likely this will not have a good earth (ground) You can prove this by using a jumper wire with alligator clips between the tank and the chassis.
I found this worked on my Command Car.
I them removed the fuel tank (not a difficult task) and then removed the sender unit from the tank. I dismantled the sender to find there was a small srpring missing from the float arm mechanism. The spring ensures there is contact betewwn the arm and the body of the sender. A new spring (taken from a tyre valve) fixed the problem.
What region in Spain are you in?
Atentamente
Atentamente
1942 WC57 Command Car
1942 WC-53 Carry-All
