WC 53 hinge area progress
Posted: Sun Nov 20, 2022 1:07 am
by Adam in Wa
The strip of metal below the tailgate (I don’t know what it’s called) on my carryall was beat up pretty badly. Since I was rebuilding the tailgate hinges I decided to remove the center section and weld in a replacement. The damaged strip is 16 gauge and I don’t have the tools to form an exact replacement, so I made it from two pieces. I used a spot weld cutter to remove the damaged piece. Once apart I decided to remove the entire piece and treat the hidden rust. I welded the cleaned and treated ends back on and then cut the center section to length. The center section has about a one inch curve in it, along its length. This would be very difficult to fabricate in one piece. I found a small crack in the lower left corner of the tailgate opening, and the factory welds were fugly, I will be addressing those at a later time.
Re: WC 53 hinge area progress
Posted: Mon Dec 05, 2022 10:06 am
by Adam in Wa
Getting there… but too cold to paint. 22 degrees F (-5 C) in the open area of my shop.
Posted: Mon Dec 05, 2022 5:25 pm
by wc 9 and 12 owner
Nice work I need to do this to my Wc 10 carryall
Posted: Mon Dec 05, 2022 11:23 pm
by Leno
Hello!!
How well finished and finished, very professional.
I admire the ability, means and time to develop all this great work. Good luck, it's turning out great.
Regards.
Posted: Mon Dec 26, 2022 9:04 pm
looking great!
Posted: Sat Jan 21, 2023 4:21 am
by Adam in Wa
Posted: Sat Jan 21, 2023 4:29 am
by Adam in Wa
good as new!
Posted: Sat Jan 21, 2023 4:34 am
by Adam in Wa
Btw, these are original reflector housings, with new reflectors. I was able to save them with some blasting and rust treatment, probably not worth the time, but many reproduction pieces leave a lot to be desired.
