I was chatting to a friend the other night, he is trying to set the axle shaft to steering knuckle (centralizing) position, but tells me the shoulder against which the inner wheel bearing cone rests has been machined. I understand this dimension is critical to correctly positioning the axle 1/2 shaft.
Once were out of lock down ( we are not permitted to leave our homes execpt to go to the supermarket or pharmacy) I will go over to his house to see if we can nut this out.
In the interim, could someone please measure the distance from the shoulder to the outer face of the stub axle where the wheel bearing retainer nuts screw on please. Inches or millimeters are both fine, we speak both languages here in NZ
Many thanks
