Better than some I've seen - you have all the structure and the captive fittings.
When you make the new ones, prime, paint, and seal them, then line the bottom with putty formed into a little channel to the drain point.
When you get to the drain hoses, the originals were too short and finished inside the double skin, so extend them a bit so anything that drains come out of the hose below the level of any sheet metal.
Of course if you live in a desert, just put those ones back ...
