9.00 x 16 Flaps for WC51
Posted: Sat Jul 07, 2018 5:33 pm
by G. Miskovsky
All,
Doing the tire thing, as I recall the combat rims use a center hole flap and not a offset one correct?
Re: 9.00 x 16 Flaps for WC51
Posted: Sun Jul 08, 2018 5:28 am
by Lang
Assuming you are not using a steel bead-lock, which has a centre hole, but are using a rubber flap. If you have one hole and need the other a hot solder iron or a drill will soon solve the problem. The Two-Piece rims have a slot so it is able to use either centre or off-set if you are stuck for the correct tube in an emergency. If you have a tube with a centre straight valve stem it will be a pain to inflate because it will hit on the wheel centre.
I believe the correct tube (and flap hole) is, centre position valve, with a long right-angle bent stem. like dual wheel trucks use.
PS * Found a great original drawing of a Dodge rim cross section but the message on this forum says "Full" when I try to attach. Definitely centre hole!
Posted: Sun Jul 08, 2018 1:04 pm
by G. Miskovsky
Lang,
Thankyou for the reply. Center it is!
