The special tools provided for working on Dodge vehicles. They would have been supplied in a standard mechanics tool box with the 41-T-3363 code and description stencilled on
The Ordnance Catalog (Ordnance Provisioning Systems) Group N, OCTOBER 5, 1942,
STANDARD NOMENCLATURE LIST NO. N-19 TOOL-SETS, MOTOR TRANSPORT.
Stock No. Piece Mark or Drawing No. NOMENCLATURE Notes
41-D-1535-25 MTM-DD-843 DRIFT, front axle shaft inner oil seal and bushing installing 1
41-D-1535 MTM-DD-827 DRIFT, front axle shaft inner oil seal installing 1
41-D-1535-50 MTM-DD-808 DRIFT, front wheel, inner bearing oil seal installing 1
41-D-1545 MTM-C-201 DRIFT, rear axle shaft inner oil seal installing 1
41-D-1546-75 MTM-C-579 DRIFT, transmission, rear oil seal installing 1
41-G-119-20 MTM-DD-837 GAGE, front end play checking 1
41-G448 MTM-DD-838 GAGE, turning radius ( for use with axle in or out of vehicle) 1
41-P-2909-40 MTM-DD-839 PULLER, front axle steering knuckle bearing 1
41-P2961 MTM-DD-840 PULLER, front and rear wheel hub 1
41-P2951-60 MTM-C499 PULLER, rear axle shaft
41-P-2951-70 MTM-DD-431 PULLER, rear spring front hanger bolt
41-P-2956-50 MTM-DD-603 PULLER, transmission reverse idler gear shaft
41-P-2958-30 MTM-C-412 PULLER, water pump fan hub
41-P-2958-50 MTM-C-498 PULLER, water pump impeller
41-R-2230-10 MTM-C-551 REFACER, waterpump housing seat
41-R-2332 MTM-C-384 REFACER and LINE BURNISHER, water pump housing seat
41-R-2389-10 MTM-C-584 REMOVER and REPLACER, main bearing upper shell
41-R-2389-55 MTM-C-373 REMOVER and REPLACER, water pump bushing
41-R-2391-40 MTM-DD-286 REPLACER, clutch pilot shaft bushing
41-R-2395-40 MTM-C-359 REPLACER, pinion oil seal installing
41-R-2405 MTM-C-528 REPLACER, water pumpshaft seal
41-T-3369-65 MTM-C-522 TOOL, timing chain case cover oil seal centering 1
41-W-1494 MTM-DD-823 WRENCH, front wheel bearing adjusting nut
41-W-1626 MTM-B-1964 WRENCH, pinion shaft bearing adjusting nut
41-W-1495 MTM-DD-824 WRENCH, pinion shaft bearing adjusting nut
41-W-1991-30 MTM-DD-389 WRENCH, rear wheel bearing adjusting nut, 1 1/2 ton
41-W-3277-40 MTM-C-525 WRENCH, spanner, adjustable, for removing differential case cap 1
41-W-1991-40 MTM-DD-437 WRENCH, rear wheel bearing adjusting nut, 3-ton truck 2
Note 1 Denotes 1942 addition
Note 2 These items to be supplied only until exhaustion of present stock, and are to be eliminated from future lists.
41-T-3363, TOOL-SET, Special, Dodge
- My garage: 57mm ATG, M3 Autocar Halftracck, M3A1 Diamond T Halftrack, 43 WC63.
https://wtmvc.shutterfly.com/ - Location: Memphis, TN
Re: 41-T-3363, TOOL-SET, Special, Dodge
That is a lot of good information......
AND a lot of typing.........
Have owned...M5A1 Stuart
Have Restored...M20
Have Restored...M20
- My garage: Dodge WC56
Nice list. Would be great to have photos from these parts...
It would indeed. Many of the common tool sets have images showing the box and contents, unfortunately this set isn't one of them.ziro wrote:Nice list. Would be great to have photos from these parts...
It's worth noting there are a bunch of tools NOT included in that set, like the special brake setting tools, and the cylinder head top dead centre measuring tool, so that set must be for a particular part of the echelon network, 2nd, 3rd, 4th, where they had been identified as needed.
I suppose the implication is these tools were used only on Dodges, while some of the other tools shown in the manuals could have been used on multiple vehicle makes.
I don't know anyone out there who has this tool set, original or pulled together from this list.
