Anyone have a (Lucas ?) part number identity /whatever for a correct ignition coil for a WC52? Condensor also. Any compatible, reliable make and readily available from an autospares thanks.
Dunc
Ignition coil (UK)
Hi Dunc
I replaced the coil and condenser on my WC51 about a month ago.
I found an old fashioned auto spares place near Lancaster & got a condenser that would fit in the dizzy cap to replace the original that'd finally packed up & they also had a 6V coil for a tenner so i got it in a ' I might need it one day' way. Then left the ignition on last week and knacked the coil so new one on too now! I'll dig out the boxes and get you the numbers. The condenser was Lucas and might have been for a Citroen... can't remember the make of the coil but i've done about 250 miles with no trouble (touch-wood!)
- Master Sergeant
Any coil from any car will work OK so long as it has an internal resistor. This will probably mean going back before the 1990's for most vehicles when external resistors (that little ceramic thing screwed on the side of the engine bay) became the standard.
Fit a new condensor. Once again this can be from anything but you will just have to go through the stack to get one with the right size, screw hole position and wire length to fit inside the distributor. take your old one down as a sample.
