Fuel sending question
boondocker
Post by boondocker »
Ok, this is probably a dumb question but oh well. I put a new gas tank in my WC, I used the same sending unit, it worked fine in the old tank, now it’s pinned on full??? I only put 5 gallons in it. It’s only one wire, and I made sure the float wasn’t hitting any baffles when I put it in. I don’t know what went wrong. Any insight would be much appreciated.
Dean
Re: Fuel sending question
The fuel gauge works by earthing, and sensing resistance to earth. If everything was working, and now it is showing full, somehow the sender unit is showing a full earth value.
Disconnect gauge at tank, reading should drop to empty, then earth the gauge lead to the chassis and it'll show full again. That will pin it down to an extra unwanted path to earth somewhere in the gauge sender, usually the insulation on the terminal to the gauge body.
boondocker
Thanks Gordon, unfortunately for me the only way to check the wire is to remove the tank again, I’m really not up for that again at this time. It took everything I had to get it back in. Guess maybe I should have checked that before I put
it in. Learning curve ⬆️ I’m working outside on a piece of plywood.
OK, many WC's have a cover plate for the sender to allow access, but maybe not yours. It'll be a sender permanent earth fault I think. :D
boondocker
No cover plate for me, I don’t get that lucky 🍀 thanks, wonder if I could add one🤔
Dozerman51
Post by Dozerman51 »
What model Wc do you have?
boondocker
It’s a 42 WC-51
beepbeep
My garage: 1944 WC51
Post by beepbeep »
boondocker wrote: Sun Aug 21, 2022 11:53 pm No cover plate for me, I don’t get that lucky 🍀 thanks, wonder if I could add one🤔
Worth doing if you don't mind cutting into, what I'm assuming is, the original wood floor. Mine is ex Norwegian Army with a steel floor replacement and a cover plate, I can get you a photo with dimensions if you want
Chris
1944 WC51
