The special tools provided for working on Dodge vehicles. They would have been supplied in a standard mechanics tool box with the 41-T-3363 code and description stencilled on
The Ordnance Catalog (Ordnance Provisioning Systems) Group N, OCTOBER 5, 1942,
STANDARD NOMENCLATURE LIST NO. N-19 TOOL-SETS, MOTOR TRANSPORT.
Stock No. Piece Mark or Drawing No. NOMENCLATURE Notes
41-D-1535-25 MTM-DD-843 DRIFT, front axle shaft inner oil seal and bushing installing 1
41-D-1535 MTM-DD-827 DRIFT, front axle shaft inner oil seal installing 1
41-D-1535-50 MTM-DD-808 DRIFT, front wheel, inner bearing oil seal installing 1
41-D-1545 MTM-C-201 DRIFT, rear axle shaft inner oil seal installing 1
41-D-1546-75 MTM-C-579 DRIFT, transmission, rear oil seal installing 1
41-G-119-20 MTM-DD-837 GAGE, front end play checking 1
41-G448 MTM-DD-838 GAGE, turning radius ( for use with axle in or out of vehicle) 1
41-P-2909-40 MTM-DD-839 PULLER, front axle steering knuckle bearing 1
41-P2961 MTM-DD-840 PULLER, front and rear wheel hub 1
41-P2951-60 MTM-C499 PULLER, rear axle shaft
41-P-2951-70 MTM-DD-431 PULLER, rear spring front hanger bolt
41-P-2956-50 MTM-DD-603 PULLER, transmission reverse idler gear shaft
41-P-2958-30 MTM-C-412 PULLER, water pump fan hub
41-P-2958-50 MTM-C-498 PULLER, water pump impeller
41-R-2230-10 MTM-C-551 REFACER, waterpump housing seat
41-R-2332 MTM-C-384 REFACER and LINE BURNISHER, water pump housing seat
41-R-2389-10 MTM-C-584 REMOVER and REPLACER, main bearing upper shell
41-R-2389-55 MTM-C-373 REMOVER and REPLACER, water pump bushing
41-R-2391-40 MTM-DD-286 REPLACER, clutch pilot shaft bushing
41-R-2395-40 MTM-C-359 REPLACER, pinion oil seal installing
41-R-2405 MTM-C-528 REPLACER, water pumpshaft seal
41-T-3369-65 MTM-C-522 TOOL, timing chain case cover oil seal centering 1
41-W-1494 MTM-DD-823 WRENCH, front wheel bearing adjusting nut
41-W-1626 MTM-B-1964 WRENCH, pinion shaft bearing adjusting nut
41-W-1495 MTM-DD-824 WRENCH, pinion shaft bearing adjusting nut
41-W-1991-30 MTM-DD-389 WRENCH, rear wheel bearing adjusting nut, 1 1/2 ton
41-W-3277-40 MTM-C-525 WRENCH, spanner, adjustable, for removing differential case cap 1
41-W-1991-40 MTM-DD-437 WRENCH, rear wheel bearing adjusting nut, 3-ton truck 2
Note 1 Denotes 1942 addition
Note 2 These items to be supplied only until exhaustion of present stock, and are to be eliminated from future lists.
41-T-3363, TOOL-SET, Special, Dodge
- tankdriver
- My garage: 57mm ATG, M3 Autocar Halftracck, M3A1 Diamond T Halftrack, 43 WC63.
https://wtmvc.shutterfly.com/ - Location: Memphis, TN
Re: 41-T-3363, TOOL-SET, Special, Dodge
That is a lot of good information......
AND a lot of typing.........![Very Happy :D](./images/smilies/icon_biggrin.gif)
1943 WC63......1942 57mm Anti-Tank
Have owned...M5A1 Stuart
Have Restored...M20
MVPA Member...President West TN Military Vehicle Collectors... https://wtmvc.shutterfly.com/
Have Restored...M20
- My garage: Dodge WC56
Nice list. Would be great to have photos from these parts... ![Embarassed :oops:](./images/smilies/icon_redface.gif)
It would indeed. Many of the common tool sets have images showing the box and contents, unfortunately this set isn't one of them.ziro wrote:Nice list. Would be great to have photos from these parts...
It's worth noting there are a bunch of tools NOT included in that set, like the special brake setting tools, and the cylinder head top dead centre measuring tool, so that set must be for a particular part of the echelon network, 2nd, 3rd, 4th, where they had been identified as needed.
I suppose the implication is these tools were used only on Dodges, while some of the other tools shown in the manuals could have been used on multiple vehicle makes.
I don't know anyone out there who has this tool set, original or pulled together from this list.
