Build Card Thread ( Sticky )
- My garage: 1945 Dodge WC51 (Febr 12 1945)
1945 Bantam T3 or Willys MBT - Location: Lidingo, Sweden
Re: Dodge Truck Build Card compilation (60 +)
Hi,
Just had to play around with Greg's blank build card and make a replica of my own card:
The original:
And the replica:
I used a few of my typewriter fonts, and a handwriting font for the lower right hand corner. The black dots (punched holes) created a headache for me until I finally found out that Times New Roman, set at 30 dpi, was just the right size. Then it was just a question of typing each "hole" and placing it where it should be (which took for ever, BTW...) I used Photoshop to fill out the card.
Now I'll locate the correct material to print it on and put it on displa together with my WC51... Any tips on materials/paper to use?
Goran N
The original:
And the replica:
Goran N
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Marked as an ambulance of the
Brazilian Expeditionary Force, Italy 1944-45
Willys MBT
ACM no 57482
Manufactured: July 1943
MVBros - Your need - our mission
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Goran,
That does look better with the "been around awhile look".
I used a plain Manila File Folder. I cut it down to 8.5" X 11" to fit in my printer.
Great idea on marking the holes! I'm going to give that a shot.
Now you have me all excited about finishing my card... There goes my weekend...
- Florence
Hi Juan,
thanks a lot for the card and plan!
Sorry for my late reply I went to Wales Nationalparks the last weeks and had nearly no internet access there.
Interesting research about the 66 and 90.
Sometimes the owners did write the WC xx number, too. (when you go with the mouse over a card in the BC compilation you can read what WC it is and where it is located today)
Greetings
Sylvia
Greetings
Sylvia
WC58 - 4229/933 July 1942 - Commander George
http://www.command-car.com
Dedicated to Dodge Command Car and Dodge Ambulance of WW2
Dodge Build Card collection:
http://www.command-car.com/technik/tech ... cards.html
well spotted Juan,
my original PhotoShop Buildcard file is somewhere in the bowels of a semi-deceased external drive.
It took me a bout 8 hours to 'build' the card so I don't think I shall be trying again anytime soon.
If I can manage to resurrect the broken drive its a simple matter to fix those errors.....its on the 'to do' list.
Brent.
WC56.
WC56.
Hi Brent,
I'll pass on a tip conserning deceased, or semi-deceased, hard drives, external or otherwise, that I got from a computer guy in California: Put your hard drive in the freezer (!) for aproximately 48 hours, and try to empty the contents of the HD to another HD that's ok.
Sounds like a crazy idea, but I managed to resurrect almost 30% of a LaCie hard drive (1 TB) that I had given up for lost....
I plugged in the drive while it was still in the freezer and ran it while it was in there.
We'd love to have access to a mock-up build card that is correct.
Good luck!
Goran N
Good luck!
Goran N
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
- Florence
3 more build cards added today - Thanks guys!
The WC57 from June and Ian was build on the same day as my WC58 - 25. July 1942
Direct link to the Build Cards:
Sylvia
Sylvia
- Florence
And one more today, 67 now!
Thanks a lot ... maybe we can make the 100 in 2011
Hi Sylvia,
isnt that amazing, 2 command cars, at opposite ends of the world but built on the same day. Wow.
1942 WC57 Command Car
1942 WC-53 Carry-All
- Florence
Hi Ian,
yes that is realy amazing - I was happy when I saw the date of yours!
Today another buildcard added - 68 now
Greetings around the world
Sylvia
Sylvia
Hi Sylvia,
Micha just got hold of a WC57, but with WC 51/52 (late) bodywork. We know little about this vehicle yet, but he will send in an application for a Build Card a.s.a.p.
BTW do you, or anybody else here for that matter, have any leads on a Command Car body? I know they're hard to find, but you've gotta ask.
The present bodywork, together with other Dodge parts, is up for trade.
Goran N
Goran N
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
I'm a bit puzzled here.
I checked the build card closest to mine, build date February 12th 1945, frame no 81741448. Dodge WC51 (?) 81757281 was built the day after, February 13th 1945. But did Dodge actually build 15.832 Dodge's between February 12, and February 13 1945? That's an awful lot of trucks to build in 24 hours!
Goran N
Goran N
Goran Noren
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
Dodge WC51 1945
Built: 2/12/1945
Willys MBT
ACM no 57482
- Florence
Hello Goran,
that is very interesting and I don't know how they could build more than 15.000 Dodge in 24 hours!?
Just an idea: maybe they had problems with filling out the cards because no cards left anymore, no personal for filling out them or had no time to fill out the cards end of 1944 - and filled out the build cards after they produced the batch of Dodge? At least at the end of WW2
Any suggestions here?
Greetings
Sylvia
Greetings
Sylvia
